[mapserver-commits] [MapServer/MapServer] a05a8d: CI: add tests for MS_MAP_NO_PATH, MS_MAP_PATTERN a...
Jeff McKenna
noreply at github.com
Mon May 3 07:20:03 PDT 2021
Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: a05a8dfd9edeed70682007167cd146aef525b888
https://github.com/MapServer/MapServer/commit/a05a8dfd9edeed70682007167cd146aef525b888
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2021-04-30 (Fri, 30 Apr 2021)
Changed paths:
M .github/workflows/start.sh
Log Message:
CI: add tests for MS_MAP_NO_PATH, MS_MAP_PATTERN and MS_MAPFILE
Commit: 9a81e82eab13f307d991d2c6d794b788474837ff
https://github.com/MapServer/MapServer/commit/9a81e82eab13f307d991d2c6d794b788474837ff
Author: Jeff McKenna <jmckenna at gatewaygeomatics.com>
Date: 2021-05-03 (Mon, 03 May 2021)
Changed paths:
Log Message:
Merge pull request #6316 from rouault/test_envvar_mapfile
Compare: https://github.com/MapServer/MapServer/compare/a70dfe1201db...9a81e82eab13
More information about the mapserver-commits
