[mapserver-commits] [MapServer/MapServer] 2c4dd8: mapshape: remove useless null terminator
Even Rouault
noreply at github.com
Tue May 4 12:58:09 PDT 2021
Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: 2c4dd8143f53e05ea8701e2b39a3d8cc35484e3b
https://github.com/MapServer/MapServer/commit/2c4dd8143f53e05ea8701e2b39a3d8cc35484e3b
Author: Max Kellermann <max.kellermann at gmail.com>
Date: 2021-05-04 (Tue, 04 May 2021)
Changed paths:
M mapshape.c
Log Message:
It's pointless to null-terminate the buffer if strcpy() overwrites it.
Commit: 2c4fe1dc2941c588a1e7cc7d2e1481b030190c2d
https://github.com/MapServer/MapServer/commit/2c4fe1dc2941c588a1e7cc7d2e1481b030190c2d
Changed paths:
M mapshape.c
Log Message:
mapshape: validate numshapes
If the value is implausible, refuse to parse the file, because that
value will be used later in memory allocations. I used the same limit
as in msSHPOpen().
DoS vulnerability found with libFuzzer.
Commit: 67d7e9eeedc73cf8ef14bdf4a0d230a1cfda61fd
https://github.com/MapServer/MapServer/commit/67d7e9eeedc73cf8ef14bdf4a0d230a1cfda61fd
Changed paths:
M mapshape.c
M mapxbase.c
Log Message:
mapshape, mapxbase: fix several memory leaks in error code paths
Leak bug found with libFuzzer.
Commit: 7c77153e7d767be858590c8492fe58bbc14dc6e0
https://github.com/MapServer/MapServer/commit/7c77153e7d767be858590c8492fe58bbc14dc6e0
Changed paths:
M mapxbase.c
Log Message:
mapxbase: validate nHeadLen
Make sure the "nFields" formula doesn't underflow, leading to a
multi-gigabyte memory allocation and probably a heap buffer overflow.
Vulnerability found with libFuzzer.
Commit: 9a41ef41cb20fe7459c8e244c229b15c9d4cad79
https://github.com/MapServer/MapServer/commit/9a41ef41cb20fe7459c8e244c229b15c9d4cad79
Author: Even Rouault <even.rouault at spatialys.com>
Changed paths:
M mapshape.c
M mapxbase.c
Log Message:
Merge pull request #6319 from MaxKellermann/fuzzer
Fixes for several security vulnerabilities found with libFuzzer
Compare: https://github.com/MapServer/MapServer/compare/9a81e82eab13...9a41ef41cb20
More information about the mapserver-commits
