[mapserver-commits] [MapServer/MapServer] 032d9d: msautotest: fix get_gdal_version() to support GDAL...
Even Rouault
noreply at github.com
Fri Aug 8 13:12:55 PDT 2025
Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: 032d9d1ba08f0b276c718658ee21b7964118f57a
https://github.com/MapServer/MapServer/commit/032d9d1ba08f0b276c718658ee21b7964118f57a
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2025-08-08 (Fri, 08 Aug 2025)
Changed paths:
M msautotest/pymod/mstestlib.py
Log Message:
msautotest: fix get_gdal_version() to support GDAL version nickname (#7317)
Fixes
Cannot validate XML because SCHEMAS_OPENGIS_NET not found. Run "python ../pymod/xmlvalidate.py -download_ogc_schemas" from msautotest/wxs
File "/home/runner/work/mapserver/mapserver/msautotest/wxs/./run_test.py", line 43, in <module>
mstestlib.get_pytests(os.path.dirname(os.path.abspath(__file__))),
File "/home/runner/work/mapserver/mapserver/msautotest/wxs/../pymod/mstestlib.py", line 536, in get_pytests
if not has_requires(version_info, gdal_version, requires_list):
File "/home/runner/work/mapserver/mapserver/msautotest/wxs/../pymod/mstestlib.py", line 111, in has_requires
if compare_version(gdal_version, item[len("GDAL>=") :]) < 0:
File "/home/runner/work/mapserver/mapserver/msautotest/wxs/../pymod/mstestlib.py", line 84, in compare_version
a_x, a_y, a_z = int(a[0]), int(a[1]), int(a[2])
ValueError: invalid literal for int() with base 10: '3 "Eganville"'
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
