[mapserver-commits] [MapServer/MapServer] 02bd52: msautotest: fix get_gdal_version() to support GDAL...
Even Rouault noreply at github.com
Fri Aug 8 13:13:08 PDT 2025
  Branch: refs/heads/backport-7317-to-branch-8-4
  Home:   https://github.com/MapServer/MapServer
  Commit: 02bd52d4791e7c0102e4aa1ca8cc7aaa8eb61695
      https://github.com/MapServer/MapServer/commit/02bd52d4791e7c0102e4aa1ca8cc7aaa8eb61695
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2025-08-08 (Fri, 08 Aug 2025)
  Changed paths:
    M msautotest/pymod/mstestlib.py
  Log Message:
  msautotest: fix get_gdal_version() to support GDAL version nickname
Fixes
Cannot validate XML because SCHEMAS_OPENGIS_NET not found. Run "python ../pymod/xmlvalidate.py -download_ogc_schemas" from msautotest/wxs
  File "/home/runner/work/mapserver/mapserver/msautotest/wxs/./run_test.py", line 43, in <module>
    mstestlib.get_pytests(os.path.dirname(os.path.abspath(__file__))),
  File "/home/runner/work/mapserver/mapserver/msautotest/wxs/../pymod/mstestlib.py", line 536, in get_pytests
    if not has_requires(version_info, gdal_version, requires_list):
  File "/home/runner/work/mapserver/mapserver/msautotest/wxs/../pymod/mstestlib.py", line 111, in has_requires
    if compare_version(gdal_version, item[len("GDAL>=") :]) < 0:
  File "/home/runner/work/mapserver/mapserver/msautotest/wxs/../pymod/mstestlib.py", line 84, in compare_version
    a_x, a_y, a_z = int(a[0]), int(a[1]), int(a[2])
ValueError: invalid literal for int() with base 10: '3 "Eganville"'
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits mailing list
