[mapserver-commits] [MapServer/MapServer] e095a1: CI: Update msautotest outputs to use Docker output...
Seth G
noreply at github.com
Sat Mar 8 01:15:06 PST 2025
Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: e095a185a32c3d34f3b131aa27bfc1405503c775
https://github.com/MapServer/MapServer/commit/e095a185a32c3d34f3b131aa27bfc1405503c775
Author: Seth G <sethg at geographika.co.uk>
Date: 2025-03-08 (Sat, 08 Mar 2025)
Changed paths:
M msautotest/gdal/expected/bilinear_float.png
M msautotest/gdal/expected/rawmode_nodata.png
M msautotest/gdal/expected/rawmode_nodata_resample.png
M msautotest/misc/expected/geopdf-iso.pdf
M msautotest/misc/expected/geopdf-ogc.pdf
M msautotest/renderers/expected/average_rgb.pdf
M msautotest/renderers/expected/baseline_text.pdf
M msautotest/renderers/expected/chartlayer_bar.pdf
M msautotest/renderers/expected/chartlayer_pie.pdf
M msautotest/renderers/expected/chartlayer_pie2.pdf
M msautotest/renderers/expected/chartlayer_pie_expressions.pdf
M msautotest/renderers/expected/chartlayer_vbar.pdf
M msautotest/renderers/expected/circle_layer.pdf
M msautotest/renderers/expected/compositing.pdf
M msautotest/renderers/expected/empty.pdf
M msautotest/renderers/expected/entity_encoded_follow_text.pdf
M msautotest/renderers/expected/geomtransform-vertex-layer.pdf
M msautotest/renderers/expected/geomtransform-vertex.pdf
M msautotest/renderers/expected/grid.pdf
M msautotest/renderers/expected/label-multifont.pdf
M msautotest/renderers/expected/label_noclip.pdf
M msautotest/renderers/expected/labelcacheoff.pdf
M msautotest/renderers/expected/labelpnt.pdf
M msautotest/renderers/expected/labelrot.pdf
M msautotest/renderers/expected/labels-anno.pdf
M msautotest/renderers/expected/labels-leader.pdf
M msautotest/renderers/expected/labels-min-distance.pdf
M msautotest/renderers/expected/labels.pdf
M msautotest/renderers/expected/legend.pdf
M msautotest/renderers/expected/legend_label_offset.pdf
M msautotest/renderers/expected/legend_sizeunits_meters.pdf
M msautotest/renderers/expected/line_label_auto.pdf
M msautotest/renderers/expected/line_label_auto2.pdf
M msautotest/renderers/expected/line_label_follow.pdf
M msautotest/renderers/expected/line_label_follow_offsetted.pdf
M msautotest/renderers/expected/line_label_follow_retry.pdf
M msautotest/renderers/expected/line_marker_pixmap.pdf
M msautotest/renderers/expected/line_marker_svg.pdf
M msautotest/renderers/expected/line_marker_truetype.pdf
M msautotest/renderers/expected/line_marker_vector.pdf
M msautotest/renderers/expected/line_offset.pdf
M msautotest/renderers/expected/line_pattern.pdf
M msautotest/renderers/expected/line_pattern_offset.pdf
M msautotest/renderers/expected/line_short_gap.pdf
M msautotest/renderers/expected/line_simple.pdf
M msautotest/renderers/expected/marker_anchorpoint.pdf
M msautotest/renderers/expected/marker_pixmap.pdf
M msautotest/renderers/expected/multilabel-leader.pdf
M msautotest/renderers/expected/multilabel.pdf
M msautotest/renderers/expected/nodata_8bit.pdf
M msautotest/renderers/expected/point-polaroffset.pdf
M msautotest/renderers/expected/point_ellipse.pdf
M msautotest/renderers/expected/point_pixmap.pdf
M msautotest/renderers/expected/point_pixmap_gif.pdf
M msautotest/renderers/expected/point_svg.pdf
M msautotest/renderers/expected/point_truetype.pdf
M msautotest/renderers/expected/point_vector.pdf
M msautotest/renderers/expected/poly-label-multiline-pos-auto.pdf
M msautotest/renderers/expected/poly-label-pos-auto.pdf
M msautotest/renderers/expected/poly_geomtransform_anchor.pdf
M msautotest/renderers/expected/polygon-as-line-offset.pdf
M msautotest/renderers/expected/polygon-as-line.pdf
M msautotest/renderers/expected/polygon-hatch-dashed.pdf
M msautotest/renderers/expected/polygon-hatch.pdf
M msautotest/renderers/expected/polygon-pixmap.pdf
M msautotest/renderers/expected/polygon-simple.pdf
M msautotest/renderers/expected/polygon-ttf.pdf
M msautotest/renderers/expected/polygon-vector.pdf
M msautotest/renderers/expected/raster_simple.pdf
M msautotest/renderers/expected/raster_simple_opacity.pdf
M msautotest/renderers/expected/reproj.pdf
M msautotest/renderers/expected/rgb_overlay.pdf
M msautotest/renderers/expected/rgb_overlay_res.pdf
M msautotest/renderers/expected/rgb_overlay_res_to8bit.pdf
M msautotest/renderers/expected/rgb_overlay_res_to8bit_dithered.pdf
M msautotest/renderers/expected/rgba_overlay_res.pdf
M msautotest/renderers/expected/text_shaping_1.pdf
M msautotest/renderers/expected/transparent_layer.pdf
M msautotest/renderers/expected/wld_rotate.pdf
M msautotest/renderers/expected/wld_upsidedown.pdf
M msautotest/renderers/expected/wmsclient.pdf
M msautotest/wxs/expected/wcs_16_ds.grd
M msautotest/wxs/expected/wcs_16_repro.grd
M msautotest/wxs/expected/wcs_20_getcov_gtiff_compress_deflate_predictor.tif
M msautotest/wxs/expected/wcs_20_post_getcov_subsettingcrs_outputcrs.tif
M msautotest/wxs/expected/wcs_mask_16_ds.grd
M msautotest/wxs/expected/wcs_mask_16_repro.grd
M msautotest/wxs/expected/wcs_netcdf_3d_input_output.nc
R msautotest/wxs/expected/wcs_netcdf_3d_input_output.nc.aux.xml
M msautotest/wxs/expected/wcs_netcdf_3d_output.nc
R msautotest/wxs/expected/wcs_netcdf_3d_output.nc.aux.xml
M msautotest/wxs/expected/wcs_netcdf_input_output_wcs10_get_coverage.nc
R msautotest/wxs/expected/wcs_netcdf_input_output_wcs10_get_coverage.nc.aux.xml
M msautotest/wxs/expected/wcs_netcdf_input_output_wcs20_get_coverage.nc
R msautotest/wxs/expected/wcs_netcdf_input_output_wcs20_get_coverage.nc.aux.xml
M msautotest/wxs/expected/wfsogr10_csvzip.zip
M msautotest/wxs/expected/wfsogr10_shapezip.zip.with_headers
M msautotest/wxs/expected/wfsogr10_shapezipmem.zip.with_headers
M msautotest/wxs/expected/wfsogr_addfiles_onelayer.zip
M msautotest/wxs/expected/wms_get_map_polygon.kmz
M msautotest/wxs/expected/wms_get_map_symbol_ext_svg_sld.png
M msautotest/wxs/wfs_ogr.map
M msautotest/wxs/wms_simple_kml.map
Log Message:
CI: Update msautotest outputs to use Docker outputs (#7250)
* Identical image outputs
* Whitespace at end of lines
* Visually identical
* Add aux file
* Manually checked in QGIS
* Remove QGIS generated AUX files
* Added whitespace at ends of lines
* zipped files seem to change on each run
* Mark zip output tests as TO_FIX as output is different on each run
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
