[mapserver-dev] Re: Python method getImageGDString for 3.7 mapscript
Sean Gillies
sgillies at i3.com
Mon Aug 19 11:05:37 EDT 2002
Sorry!
Forgot to attach the code. I've put it inside the imageObj
methods in mapscript.i.
Sean Gillies wrote:
> Last week I submitted code for a Python getImageString method
> that Steve Lime added to the CVS.
> I've upgraded the code so that it works with the developing
> mapserver and gd-2.0.1. You'll notice that the code looks
> almost exactly like msSaveImageGD().
> Have not tested it with GIF or WBMP, but don't see anything
> wrong with my calls to gdImageGifPtr() or gdImageWBMPPtr().
> Soon I'll be able to contribute a Python getImageGDALString.
> Please let me know if you think this is useful code.
> cheers,
Sean Gillies Applications Developer
i-cubed : information integration & imaging LLC
970-482-4400 voice
970-482-4499 fax http://www.i3.com
// Method getImageGDString renders the imageObj into image data and returns
// it as a string. Inspired by and used like the msSaveImageGD() method.
// Python only at this time.
// Questions and comments to Sean Gillies <sgillies at i3.com>
#ifdef SWIGPYTHON
PyObject *getImageGDString() {
unsigned char *imgbytes;
int size;
PyObject *imgstring;
#if GD2_VERS > 1
if (self->format->imagemode == MS_IMAGEMODE_RGBA) {
gdImageSaveAlpha(self->img.gd, 1);
else if (self->format->imagemode == MS_IMAGEMODE_RGB) {
gdImageSaveAlpha(self->img.gd, 0);
#endif
if (strcasecmp("ON", msGetOutputFormatOption(self->format, "INTERLACE", "ON" )) == 0) {
gdImageInterlace(self->img.gd, 1);
if (self->format->transparent) {
gdImageColorTransparent(self->img.gd, 0);
if (strcasecmp(self->format->driver, "gd/gif") == 0) {
#ifdef USE_GD_GIF
imgbytes = gdImageGifPtr(self->img.gd, &size);
#else
msSetError(MS_MISCERR, "GIF output is not available.", "getImageGDString()");
return(MS_FAILURE);
#endif
else if (strcasecmp(self->format->driver, "gd/png") == 0) {
#ifdef USE_GD_PNG
imgbytes = gdImagePngPtr(self->img.gd, &size);
#else
msSetError(MS_MISCERR, "PNG output is not available.", "getImageGDString()");
return(MS_FAILURE);
#endif
else if (strcasecmp(self->format->driver, "gd/jpeg") == 0) {
#ifdef USE_GD_JPEG
imgbytes = gdImageJpegPtr(self->img.gd, &size, atoi(msGetOutputFormatOption(self->format, "QUALITY", "75" )));
#else
msSetError(MS_MISCERR, "JPEG output is not available.", "getImageGDString()");
return(MS_FAILURE);
#endif
else if (strcasecmp(self->format->driver, "gd/wbmp") == 0) {
#ifdef USE_GD_WBMP
imgbytes = gdImageWBMPPtr(self->img.gd, &size, 1);
#else
msSetError(MS_MISCERR, "WBMP output is not available.", "getImageGDString()");
return(MS_FAILURE);
#endif
else {
msSetError(MS_MISCERR, "Unknown output image type driver: %s.", "getImageGDString()", self->format->driver );
return(MS_FAILURE);
// Create a Python string from the (char *) imgbytes.
// The gdImage*Ptr functions return a size for just this purpose.
imgstring = PyString_FromStringAndSize(imgbytes, size);
// The gd docs recommend gdFree()
gdFree(imgbytes);
return imgstring;
#endif
