[mapserver-dev] Transparency attribute on Layer Object
David Graham dgraham at i3.com
Mon Aug 19 13:55:30 EDT 2002
Daniel:
That is strange.  I looked for it in the MapFile refrence and it is not
there.
http://mapserver.gis.umn.edu/doc36/mapfile-reference.html
I don't think it exists for raster stuff.  My look into mapraster.c did
not turn up anything that looked like it.
Dave
Daniel Morissette wrote:
>Dave,
>I never used it myself, but you might want to have a look at the
>TRANSPARENCY parameter that was added at the layer level in 3.6:
>http://mapserver.gis.umn.edu/wilma/mapserver-users/0204/msg00292.html
>I'm not sure whether this feature is properly supported with imagery
>and/or 24 bits output in 3.7 yet... I'll let Frank/Steve reply on that.
>Daniel
>David Graham wrote:
>>Developers:
>>I would like to know if anyone is working on a project to add transpency
>>to Layer Objects that are of type raster data.  If not I am trying to
>>size the effort required to add the ability to specify a transparency
>>parameter in the layer object (map file) that could indicate % of the
>>imagery to blend with existing data at rendering time.  The idea is to
>>be able to blend multiple raster layers each overlaying the last.  Since
>>the we now have 24bit support this should not be too difficult.
>>Currently my requirements are only for Raster data, but it would be
>>useful to eventualy extend the functionality to vector polygons filling
>>also.  I am less familiar with that side of the code.
>>Dave Graham
>>David W. Graham
>>Director of Geospatial Applications Development
>>information integration and imaging, LLC
>>201 Linden St, Third Floor
>>Fort Collins, CO 80524
>>(970) 482-4400
>>dgraham at i3.com
>>http://www.i3.com
David W. Graham
(970) 482-4400
dgraham at i3.com
http://www.i3.com
