[mapserver-dev] Transparency attribute on Layer Object
Norman Vine
nhv at cape.com
Mon Aug 19 14:17:51 EDT 2002
David Graham writes:
>I don't think it exists for raster stuff. My look into
>mapraster.c did
>not turn up anything that looked like it.
Following against current CVS files
<505> mapserver
$ grep "transparency" *.c
mapdraw.c: if (layer->transparency > 0) {
mapdraw.c: if( MS_RENDERER_GD(map->outputformat) && layer->transparency >
0 )
mapdraw.c: gdImageCopyMerge(img_cache, image->img.gd, 0, 0, 0, 0,
image->img gd->sx, image->img.gd->sy, layer->transparency);
mapfile.c: layer->transparency = 0;
mapfile.c: if(getInteger(&(layer->transparency)) == -1) return(-1);
mapfile.c: scalebar->transparent = MS_NOOVERRIDE; // no transparency
mapgd.c: * transparency should be set (for RGBA images). Note this
function o ly
mapoutput.c: 32bit RGBA (A=alpha/transparency) result image.
Note hat the
mapoutput.c: TRANSPARENT - A value of "ON" or "OFF" indicating whether
transpar ncy
mapwms.c: ** the transparency if needed.
shp2img.c: fprintf(stdout," -t: enable transparency\n" );
shp2img.c: if(strncmp(argv[i], "-t", 2) == 0) /* transparency */
shp2pdf.c: /*if(strncmp(argv[i], "-t", 2) == 0) transparency
<506> mapserver
$ grep "transparency" *.h
map.h: int transparency; // transparency value 0-100
HTH
Norman
