[mapserver-dev] MapServer: Add Points on the fly
Pradeep
pradeepkumar at infotech.stph.net
Fri Aug 30 00:42:34 EDT 2002
Hello
We are building a sample application using Maserver, we have a
requirement
in which we are supposed to add user defined pointson the map that are
ultimately written to the data base or the shape files, I wish to know if we
can dynamically add points information to the map from the front end. If so
can any one help me with getting started, through some examples, or some
guidance for which I will be very grateful...
Thank You
Pradeep
