[mapserver-dev] Design Documents
Administrator jnovak at novacell.com
Sat Nov 9 20:27:37 EST 2002
Pradeep,
Are you creating the COM interfaces to enable embedding, etc in
batch/GUI programs, or are you doing this to enable interfacing with IIS
and/or ASP via COM rather than using the CGI functionality ?
John Novak
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Saturday, November 09, 2002 2:56 PM
To: pradeepkumar at infotech.stph.net; mapserver-dev at lists.gis.umn.edu
Subject: Re: [mapserver-dev] Design Documents
I think it would make the most sense for a COM module to follow
MapScript. Assuming your dll is destined for public consumption that
would make it much easier to use. The file mapscript.i in the mapscript
directory documents much of the SWIG generated interface. I can help
further if this is of interest to you.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Pradeep" <pradeepkumar at infotech.stph.net> 11/08/02 05:02 AM >>>
Hi User Group,
    I am destined to create a COM dll for MapServer. I need all the Help
to understand The Programmatic flow and design of mapserver, can some
one help me understand mapserver from a development perspective, Any
shred of Info in that direction will be gladly appreciated.
Thanks ,
Pradeep
Proj Lead
Infotech Enterprises Ltd
Hyderabad
India
