[mapserver-dev] labelcache and multiple calls to msDrawMap
Jill Vogel
jill at emeraldgate.com
Thu Oct 10 19:23:57 EDT 2002
This sounds like the easist solution for me as well. What's the best
way to get an old bug noticed?
Out of curiosity, why did you (Daniel) need to clear the label cache?
On Mon, Oct 07, 2002 at 04:03:36PM
-0400, Daniel Morissette wrote:
> Steve Lime wrote:
> > What language are you using? In perl there is a method for a
> > labelCacheObj to clear the cache. You'd use it like this:
> > $map->{labelcache}->freeCache();
> > and then continue drawing. I don't know if such a beast exists for
> > PHP/MapScript.
> Nope, this method is not available in PHP. I filed a bug about moving
> this code to a msFreeLabelCache() function in libmap.a and adding a call
> to it in PHP:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=207
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
