[mapserver-dev] labelcache and multiple calls to msDrawMap
Daniel Morissette
morissette at dmsolutions.ca
Mon Oct 21 14:35:49 EDT 2002
Makes complete sense to me. The $map->draw() call creates a new image
anyway, so it would make little sense to carry an old label cache in a
new map image.
Daniel
P.S. I cc'd the message to the mapserver-dev list so that we start using
it again.
Steve Lime wrote:
> Thought about it a bit more. We could add the label cache clearing call
> to the front
> of the drawing process (i.e. make sure the cache is clear before
> starting). That way
> it would remain accessible after drawing for post-processing. Sound
> ok?
> Steve
> >>> Daniel Morissette <morissette at dmsolutions.ca> 10/16/02 05:11PM >>>
> Jill Vogel wrote:
> > > I was not the one who suggested clearing the label cache, I think
> it was
> > > Steve.
> > Oops..sorry..
> > > But anyway I believe the reason was that after a call to
> > > $map->draw() the cache was not cleared and then if you would draw
> > > another map in the same script execution then the labels accumulate
> in
> > > the cache and the old ones would be drawn again on the new map.
> > > Daniel
> > That's the problem I've been seeing. Is there any reason the cache
> > shouldn't be cleared after the map is drawn? I can't tell if it
> makes
> > any future draws of the same map faster.
> I don't see any reason why the cache could not be cleared
> automatically
> after the map is drawn. I really doubt that not clearing the cache
> would make things faster. If anything it would make them slower since
> the cache grows and more labels have to be drawn each time. BTW this
> is
> not controlled by MapScript, it's the MapServer internal msDrawMap()
> function that behaves this way.
> I'm not sure if Steve really intended things to be this way or if he
> just forgot to clear the label cache at the end of a map draw. I will
> have to let him answer on this.
> Daniel
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
