[Mapserver-dev] mapserver & win2k
Dubnansky, Andrew
adubnansky at 3eTI.com
Mon Aug 11 15:47:57 EDT 2003
I have downloaded & installed ms40_gif_pg.zip & ms366_gif_wms.zip (on
separate win2k machines) .
I am using win2k and IIS 5.0.
I have installed everything according to the respective "readme" files,
the only minor exception being that I have put mapserv.exe in the
"scripts" directory in IIS instead "cgi-bin", and:
(1) Version 4 was missing a file called "libpq.dll" which I found on the
internet and copied to my system directory.
(2) Version 3.6.6 was missing a file called "zlib.dll" which I found on the
I cannot get the ver. 3.5 demo or the ver. 4.0 demo to run at all. The
"demo_init" webpage will bring up the display page, but there are red "x"s
where the map, legend, and scalebar image should be.
Typing "mapserv -v" at the command line returns the expected responses.
e.g. - MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I am at a loss to locate what I have missed. I have double checked the
directory struct, capitalization issues, etc.Any help would be very
appreciated.
thanks in advance,
- AJ
