[Mapserver-dev] 3.6 branch CVS checkout
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Aug 8 11:31:18 EDT 2003
Hi Dave,
Thanks very much! I'll re-pull from CVS and test the final version when
I find a spare moment!
Cheers,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
> -----Original Message-----
> From: David Blasby [mailto:dblasby at refractions.net]
> Sent: 07 August 2003 19:10
> To: Mark Cave-Ayland
> Cc: 'Daniel Morissette'; mapserver-dev at lists.gis.umn.edu
> Subject: Re: [Mapserver-dev] 3.6 branch CVS checkout
> Mark Cave-Ayland wrote:
> >>I don't know if the PostGIS folks replied to you already,
> but just so
> >>you know I checked in CVS and what you got from CVS is
> >>correct: the last
> >>update to mappostgis.c in CVS was made on 2002/11/15.  So it
> >>seems that
> >>nobody ever committed the June version in the 3.6 branch.
> Its now commited.
> dave
