[Mapserver-dev] About extending mapserver...
Chris G. Nicholas cgn at globexplorer.com
Wed Aug 27 06:14:20 EDT 2003
I have had success using the SWIG/Java interfaces to do the basics of loading and rendering mapfiles...
Chris Nicholas
GlobeXplorer
-----Original Message-----
From:	Attila Csipa [mailto:plists at prometheus.org.yu]
Sent:	Wed 8/27/2003 1:41 AM
To:	mapserver-dev at lists.gis.umn.edu
Cc:
Subject:	[Mapserver-dev] About extending mapserver...
>Could you put together a more detailed description of what
>you're working on, it's benefits and so on and send it to the developer
>list?
I have a question concerning an extension to mapserver. My current project
involves creating a versatile java database extender (called JADE), which can
wrap just about any function or translation between an application and a sql
database. As I mentioned above, this project is in java, however that does
not mean it cannot be linked to other non-java applications (such as
mapserver). How does this work ? Mapservers sees JADE as just another opengis
implementing database and passes the appropriate sql queries. JADE then
analyzes the query and sees what can be done by the underlying database
natively. What cannot be done that way is done inside JADE itself, some by
simply rewriting queryes and some by returning column data and applying the
appropriate operations. This of of course incurs a variable amount of
performance penalty depending on the cost of the operation and amount of data
moved around. These are the two basic downsides - a performance penalty
(which very much depends of the complexity of the query itself) and that,
since it is in java, it requires a (fairly recent) java runtime environment
(JRE) or SDK. The whole point of this is to make the sql extendend functions
and data types totally transparent to the application and/or the user while
allowing the use of full potential of the used RDMS (specific functions,
variables, types, syntax, etc). This extender would allow the use of
virtually any even remotely sql compatible database if it has JDBC drivers
(that's 99% of all database engines and vendors, see
http://servlet.java.sun.com/products/jdbc/drivers and
http://java.sun.com/products/jdbc/industry.html), without any additional
modules (apart from JADE itself). So if you have a JDBC driver, and it can
take a select/insert/update statement, chances are it can be used. Another
nice thing is that the extended functions are pluggable, so adding new
functions, or even changing the underlying database engine does not require
the recompile of nor MapServer nor JADE. This would of course make my mysql
non-spatial wrapper obsolete since it does what mygis did + allows the usage
of opengis functions in the queries, etc. The question is how do you feel
about adding java code to mapserver (this would of course be a non-default
--with-jade option) ?
Regards,
Attila
PS. A list of engines that could be (well, at least to a certain level of
functionality) used through JADE:
4th Dimension (4D RDBMS), ADABAS, ALLBASE SQL, Advantage Database Server,
BASIS, Birdstep RDM Server, CA-IDMS, CISAM, Cache, Centura SQLBase, Clipper,
Cloudscape, CodeBase, D3, DABroker, DB2, DBMaker, DL/I, DMSII, DaffodilDB,
DataFlex/PowerFlex, Datacom, Domino, ECB, EDA, Empress RDBMS, Enscribe,
Essentia, FireBirdSQL , FormWeb, FoxBase, FoxPro, FrontBase, HSQLDB,
Hypersonic SQL, IBM AS/400, IDMS, IMS, Image/Turboimage, ImageSQL, Informix,
Ingres, InstantDB, InterBase, JDBC, JDataStore, LDAP, MS Access, MS SQL
Server, Mimer SQL, MySQL, News Server, Nonstop SQL/MP, ODBC, OS/390
Sequential Files, OleDB-Provider, OpenBase, OpenIngres, Oracle, PICK,
Paradox, Pervasive.SQL, PointBase, PostgreSQL, Primebase SQL Database Server,
Progress, Quadcap, RDB, RMS, Recital, Redbrick Warehouse, SAP DB, SAS,
SESAM/SQL-Server, SOLID Embedded Engine, SOLID SynchroNet, SQL/DS, SUPRA
Server SQL, SearchServer, Sequential, Solid Server, Sybase, Teradata RDBMS,
Text (CSV, Tab separated etc.), ThinkSQL, TinySQL, TurboIMAGE, UNIFY, VFP,
VSAM, XML, YARD-SQL, dBase, kdb, mSQL, xbase, xbase Primebase SQL Database
Server
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
