[Mapserver-dev] About extending mapserver...
Sean Gillies
sgillies at frii.com
Wed Aug 27 09:19:58 EDT 2003
On Wednesday, August 27, 2003, at 02:41 AM, Attila Csipa wrote:
>> Could you put together a more detailed description of what
>> you're working on, it's benefits and so on and send it to the
>> developer
>> list?
> I have a question concerning an extension to mapserver. My current
> project
> involves creating a versatile java database extender (called JADE),
> which can
> wrap just about any function or translation between an application and
> a sql
> database. As I mentioned above, this project is in java, however that
> does
> not mean it cannot be linked to other non-java applications (such as
> mapserver). How does this work ? Mapservers sees JADE as just another
> opengis
> implementing database and passes the appropriate sql queries.
The best use (IMO) would be to write a JADE server that provides a
network
interface to arbitrary RDBMS.
MapServer -- HTTP --> JADE Server --- HTTP ---> RDBMS
Like you said, we can treat JADE as if it is a PostGIS database, yes?
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
