[Mapserver-dev] Testing thread-safety
Daniel Morissette morissette at dmsolutions.ca
Tue Dec 16 18:46:44 EST 2003
Jean-Francois.Doyon at ccrs.nrcan.gc.ca wrote:
> Any ideas on what's going on here ? Is the PHP regex implementation
> sensitive to whether it's a module or not maybe ? Could I use "apache" for
> now, if only just for testing ?
Yes, the PHP configure option --with-regex=system behaves differently
whether it is compiling as a module or as a CGI.  Actually when you
compile as a module there is absolutely no way to use the system regex.
This is a problem that I expected and for which I still don't have a
nice solution, other than modifying MapServer (the core) to build with
the PHP regex which can be quite a pain. My workaround is to configure
PHP as a CGI, then configure MapServer, and then reconfigure PHP as a
module and compile it... basically fooling the configure as you did,
except that in my case it worked. ;)
FYI there's a PHP bug that talks about this but I never got any feedback
from them: http://bugs.php.net/bug.php?id=25704
So where do we go from here? I've filed this as a bug and will update
the bug as soon as I have a solution:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=520
This PHP MapScript issue is one of my top priorities before the next
release.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
