[Mapserver-dev] Re: time support
Daniel Morissette
morissette at dmsolutions.ca
Tue Dec 16 18:25:29 EST 2003
(I decided to move this to mapserver-dev)
Steve Lime wrote:
> Do you mean TILEINDEX or the new TIMEINDEX? I could certainly see doing
> filtering on the TIMEINDEX, especially as applied to non-raster data.
> Using filters on tiles could certainly be done but would there be any
> real practical use for the output. The new TIMEINDEX is accomanied by a
> TIMEID, and the TIMEID could be interpreted as a MapServer expression so
> you could process mutiple files at one time.
I didn't know about the name of the new TIMEINDEX so I really meant
TILEINDEX.
My idea was simply that instead of creating a new TIMEINDEX we could
simply extend the existing TILEINDEX to support filter expressions. The
expression could be based on time or on any other attribute in the
tileindex file.
We would also need to extend the expressions stuff in MapServer to
support time comparisons and time ranges. That would be a generic
enhancement to the expression stuff and could be class EXPRESSIONs and
not just in the layer FILTER.
Does it make more sense? I'm scared I'm not expressing myself very well...
> That would be more work to
> add than simply interpreting TIMEID as a single value.
I actually thought that extending the TILEINDEX to support FILTER would
be simpler. Would it not just be a matter of adding a call to
msEvalExpression() in the code that scans the tile index?
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
