[Mapserver-dev] Re: 3.7 and native image rendering support
Administrator jnovak at novacell.com
Tue Feb 11 02:49:03 EST 2003
This is a bit late, but...
I've been using nothing but PNG files as output, and I have local
changes that allow me to render layers with alpha blends.
What is the alternative to PNG output files if this support is
deprecated ?
IMHO, this seems like a rather large change to start at this late date
in the 3.7 development cycle, as it's core functionality.
John Novak
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Friday, February 07, 2003 2:55 PM
To: warmerdam at pobox.com
Cc: Mapserver-dev at lists.gis.umn.edu
Subject: Re: [Mapserver-dev] Re: 3.7 and native image rendering support
The PNG and GIF support are pure fluff in my mind. I can't imagine
people use them much.
I've always considered a base version of MapServer to be made up of GD
and LibTiff and perhaps Freetype. That's just my history I guess.
3.7 is not ready, so now's the time. I'm still fixing joins (almost
done) but graticule code, oracle spatial fixes and I imagine other stuff
are still being finalized. EPPL7 OGR support would be crucial for
several groups here in MN.
I can ditch the old drivers and screw around with msDrawRasterLayer, as
you know I'm not
afraid to dive right in. The 8-bit/24-bit stuff is complicated so this
would have to make life easier...
Steve
>>> Frank Warmerdam <warmerdam at pobox.com> 02/07/03 04:40PM >>>
Steve Lime wrote:
> Currently a lite version requires libtiff anyway, and since you're
> distributing binaries it doesn't seem that bad. Building GDAL from
> source may be a pain though. (Out of curiosity does the default build
> support LZW TIFF or would that require a custom
> build?)
Steve,
Why does a lite version require libtiff?  The default build of GDAL's
internal libtiff TIFF driver supports decompressing LZW but not
compressing them.
> My vote is for simplification...
That's an important vote.  When would we strip away stuff?
Conservatively I would like to see such a change happen post-3.7 though
that puts us in the ackward position of possible releasing a 3.7 with
some buggy drivers.
Also, who would implement this?  I guess if we just strip out everything
bug GDAL it wouldn't be a big job.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Mapserver-dev mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
