[Mapserver-dev] msWMSDispatch(): General error message
Daniel Morissette
morissette at dmsolutions.ca
Thu Jan 23 09:42:03 EST 2003
Hi Roland,
Sorry for the lack of replies. I saw your other posts as well and it
seems that you must be running into an odd configuration bug, but I
haven't had time to check that yet. Did you 'make clean; make' after
the last time you ran configure? I'll try to have a look if I can find
a minute and will let you know what I find.
Daniel
Roland Forster wrote:
> Hello,
> i built the mapserver binary with the following configuration:
> ./configure --without-tiff --with-gd --enable-force-freetype2
> --with-proj --with-gdal --with-ogr --with-wmsclient
> After compiling i sent the request:
> ./mapserv -v
> i got the following answer:
> MapServer version 3.6.4 PUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
> INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
> Starting the itasca demo with demo_init.htm i got the message::
> msWMSDispatch(): General error message. WMS support is not available.
> Does anyone know why i don't get support for wms? What is going wrong?
> regards,
> Roland
