[Mapserver-dev] msWMSDispatch(): General error message
Roland Forster roland.forster at knuut.de
Thu Jan 23 10:52:19 EST 2003
Hi Daniel,
thank you for answering.
Meantime i found the reason. it seems that there is a bug in gcc vers. 3.2.
(error message during compilation mapserver:
cc1: warning: changing search order for system directory
"/usr/local/include"
cc1: warning:   as it has already been specified as a non-system directory)
i set up a new version (3.2.1) and made the compilation once again.
Now it works!
Greetings,
Roland
----- Original Message -----
From: "Daniel Morissette" <morissette at dmsolutions.ca>
To: "Roland Forster" <roland.forster at knuut.de>
Cc: <mapserver-dev at lists.gis.umn.edu>
Sent: Thursday, January 23, 2003 3:42 PM
Subject: Re: [Mapserver-dev] msWMSDispatch(): General error message
> Hi Roland,
> Sorry for the lack of replies.  I saw your other posts as well and it
> seems that you must be running into an odd configuration bug, but I
> haven't had time to check that yet.  Did you 'make clean; make' after
> the last time you ran configure?  I'll try to have a look if I can find
> a minute and will let you know what I find.
> Daniel
> Roland Forster wrote:
> > Hello,
> > i built the mapserver binary with the following configuration:
> > ./configure --without-tiff --with-gd --enable-force-freetype2
> > --with-proj --with-gdal --with-ogr --with-wmsclient
> > After compiling i sent the request:
> > ./mapserv -v
> > i got the following answer:
> > MapServer version 3.6.4 PUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
> > INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
> > Starting the itasca demo with demo_init.htm i got the message::
> > msWMSDispatch(): General error message. WMS support is not available.
> > Does anyone know why i don't get support for wms? What is going wrong?
> > regards,
> > Roland
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
