[Mapserver-dev] msWMSDispatch(): General error message
Daniel Morissette morissette at dmsolutions.ca
Thu Jan 23 11:23:21 EST 2003
I don't undertand why the header files search order would make any
difference for this type of problem, but anyway, since it works now we
won't spend more time on this.  My guess is that it's the complete
recompilation that cleaned up your build directory and fixed the issue.
If anyone else runs into a similar issue with msWMSDispatch() again then
please file a bug in bugzilla about this.
Daniel
Roland Forster wrote:
> Hi Daniel,
> thank you for answering.
> Meantime i found the reason. it seems that there is a bug in gcc vers. 3.2.
> (error message during compilation mapserver:
> cc1: warning: changing search order for system directory
> "/usr/local/include"
> cc1: warning:   as it has already been specified as a non-system directory)
> i set up a new version (3.2.1) and made the compilation once again.
> Now it works!
> Greetings,
> Roland
> ----- Original Message -----
> From: "Daniel Morissette" <morissette at dmsolutions.ca>
> To: "Roland Forster" <roland.forster at knuut.de>
> Cc: <mapserver-dev at lists.gis.umn.edu>
> Sent: Thursday, January 23, 2003 3:42 PM
> Subject: Re: [Mapserver-dev] msWMSDispatch(): General error message
> > Hi Roland,
> > Sorry for the lack of replies.  I saw your other posts as well and it
> > seems that you must be running into an odd configuration bug, but I
> > haven't had time to check that yet.  Did you 'make clean; make' after
> > the last time you ran configure?  I'll try to have a look if I can find
> > a minute and will let you know what I find.
> > Daniel
> > > Hello,
> > > i built the mapserver binary with the following configuration:
> > > ./configure --without-tiff --with-gd --enable-force-freetype2
> > > --with-proj --with-gdal --with-ogr --with-wmsclient
> > > After compiling i sent the request:
> > > ./mapserv -v
> > > i got the following answer:
> > > MapServer version 3.6.4 PUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
> > > INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
> > > Starting the itasca demo with demo_init.htm i got the message::
> > > msWMSDispatch(): General error message. WMS support is not available.
> > > Does anyone know why i don't get support for wms? What is going wrong?
> > > regards,
> > > Roland
