[Mapserver-dev] Fwd: Re: MapServer MySQL interface
David Graham
dgraham at i3.com
Tue Jan 28 17:22:19 EST 2003
David Blasby wrote:
>> As you maybe noticed my
>>connector implementation is based on almost pure ansi sql, so with
>>minimal changes it can be used practically with ANY sql database. It IS
>>slower than postgis, but even with postgis-mysql 4.1 available, this
>>solution is an option because it does not require to jump on a
>>relatively unstable new mysql, does not require to install postgis if
>>you do not already have it and, finally, it does not require additional
>>knowledge beside plain sql to use and modify. So basically it is a
>>'sql-lite' connector - compatible with practically everything and easy
>>to use, the downside being slower than a regular postgis approach.
>But, please please please consider following the OGC SF SQL spec!!
>dave
I would also say please support the OGC SQL 99-049 spec. It is pretty
easy to implement, I just turned on an OGC database for a client who
wants the fexiblilty to change database platforms in the future. It
keeps the technology moving in the same direction and makes your code
more reusable for future projects.
Dave Graham
David W. Graham
Director of Geospatial Applications Development
information integration and imaging, LLC
201 Linden St, Third Floor
Fort Collins, CO 80524
(970) 482-4400
dgraham at i3.com
http://www.i3.com
