[Mapserver-dev] Proposal for mapfile IO changes for MapServer
4.1
Paul Spencer
spencer at dmsolutions.ca
Wed Jul 2 12:52:15 EDT 2003
I like this idea, it is something that I wanted for supporting MapEdit
development. The workaround that we use is to save a temporary copy of
the mapfile and use msLoadMap( filename, path_to_use ) where path_to_use
provides a way of telling mapserver to *think* it loaded the mapfile
from elsewhere. This would eliminate two file IO steps and remove a
bunch of hairy logic.
Cheers,
Paul
Sean Gillies wrote:
> Hi,
> I'd like to proposal a change to the manner in which mapfiles
> are read and written for 4.1. My proposed changes would enable
> us to write and load mapfile fragments. Would love to hear
> what you think of this proposal.
> To start, I'd like to see msLoadMap() overhauled so that all
> the work is performed by a msLoadMapString() function. Then
> we could reduce msLoadMap() to something like the following
> pseudocode:
> msLoadMap(filename)
> fh = open(filename)
> map_string = fh.read()
> map = msLoadMapString(map_string)
> I'd also like to see this extended to layers, classes, etc.
> It would be really handy to take an existing map and then
> add a layer defined in a string like in this mapscript
> layer_string = 'NAME "foo"\nTYPE POLYGON\n' # for example
> layerobj = layerObj(mapobj, layer_string)
> An msLoadLayerString() function would be used in this new layerObj
> constructor.
> As well, I'd like to see *writeString() functions for map, layer,
> classes, and have msSaveMap() rewritten to call these.
> cheers,
> Sean
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
Paul Spencer
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
