[Mapserver-dev] Problem running CVS version...
Steve Lime
steve.lime at dnr.state.mn.us
Tue Jul 8 09:06:11 EDT 2003
Cool thanks. In my case I wasn't requesting anything just whatever the
default was. Glad it's fixed.
Steve
>>> Frank Warmerdam <warmerdam at pobox.com> 07/08/03 7:36 AM >>>
Steve Lime wrote:
> Hi Folks: I'm trying to debug some new join code but have run into an
> error elsewhere in code that I've never had a part in maintenance.
When
> running shp2img on even a simple mapfile core is dumped. Mpatrol and
gdb
> both point to msCreateDefaultOutputFormat() as the source of the seg
> fault. Can someone else out there confirm the problem. Any recent
> changes in that file or perhaps map.h that might cause this?
Steve,
I have committed a fix to mapoutput.c. It seems that Assefa added the
ability
to keep user defined formats separate from default ones, but the code
was
crashing when a unavailable driver was requested (such as GD/GIF), an
otherwise perfectly legal thing to do.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
