[Mapserver-dev] php_mapscript memory error
Nuno Cabrita nuno.cabrita at elementodigital.pt
Thu Jul 17 12:10:11 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0009_01C34C86.4888CF40
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
I have just compile mapserver 3.6.6 with gd 1.8.4, and created the PHP
module (php_mapscript.dll) for PHP 4.2.3.
Almost everything works, but when I try to create a dbase file for a
shape I get a php memory error.
Does anyone had the same problem?
Does anyone have a clue of what it could be?
=20
Elemento Digital,
Consultoria, Marketing e Desenvolvimento Inform=E1tico, Lda
Site:  <http://www.elementodigital.pt/> www.elementodigital.pt
Tel: +351 265 530 140
Fax: +351 265 530 149
Avenida Bento Gon=E7alves, 22B
2910-431 Set=FAbal
PORTUGAL
=20
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C34C86.47F19850">
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:SpellingState>Clean</w:SpellingState>
  <w:GrammarState>Clean</w:GrammarState>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:HyphenationZone>21</w:HyphenationZone>
  <w:EnvelopeVis/>
  <w:Compatibility>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]-->
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0cm;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
p
	{mso-margin-top-alt:auto;
	margin-right:0cm;
	mso-margin-bottom-alt:auto;
	margin-left:0cm;
	font-size:12.0pt;
span.EmailStyle17
	{mso-style-type:personal-compose;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
span.SpellE
	{mso-style-name:"";
	mso-spl-e:yes;}
span.GramE
	{mso-style-name:"";
	mso-gram-e:yes;}
@page Section1
	{size:595.3pt 841.9pt;
	margin:70.85pt 3.0cm 70.85pt 3.0cm;
	mso-header-margin:35.4pt;
	mso-footer-margin:35.4pt;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Table Normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
	mso-para-margin:0cm;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DPT link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DEN-GB =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>I have just compile =
<span
class=3DSpellE>mapserver</span> 3.6.6 with <span class=3DSpellE><span =
class=3DGramE>gd</span></span>
1.8.4, and created the PHP module (php_mapscript.dll) for PHP =
4.2.3.<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>Almost everything =
works, but
when I try to create a dbase file for a shape I get a <span =
class=3DSpellE>php</span>
memory error.<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>Does anyone <span
class=3DGramE>had</span> the same problem?<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
lang=3DEN-GB
style=3D'font-size:12.0pt;mso-ansi-language:EN-GB'>Does anyone have a =
clue of
what it could be?<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'><o:p>&nbsp;</o:p></span=
></font></p>
<p><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;font-family:Arial;
mso-no-proof:yes'>Elemento Digital,<br>
Consultoria, Marketing e Desenvolvimento Inform=E1tico, Lda<br>
*********************************************************************<br>=
Site: </span></font><span style=3D'mso-no-proof:yes'><a
href=3D"http://www.elementodigital.pt/"><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>www.elementodigital.pt</span=
></font></a><br>
</span><font size=3D2 face=3DArial><span =
mso-no-proof:yes'>Tel: +351 265 530 140<br>
Fax: +351 265 530 149<br>
Avenida Bento Gon=E7alves, 22B<br>
2910-431 Set=FAbal<br>
PORTUGAL<br>
*********************************************************************</sp=
an></font><o:p></o:p></p>
style=3D'font-size:
12.0pt'><o:p>&nbsp;</o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0009_01C34C86.4888CF40--
