[Mapserver-dev] Help
Bart van den Eijnden
bartvde at xs4all.nl
Thu Jul 17 15:44:17 EDT 2003
are you using version 4.0 beta 2?
If not try upgrading, because error messages did not get through properly
before.
After upgrade you will get the complete Oracle error if applicable.
Best regards,
Bart
On Thu, 17 Jul 2003 16:42:18 +0700, Utaitip Poonsen <utaitip at hotmail.com>
wrote:
> Hello
> I have problem when I adding layer from oracle spatial
> I use oracle9i and I have recently downloaded Mapserver & MapLab software
> and configured
> with IIS as well as Apache web server. I could successfully able to run
> the demo application of MapServer in both the environments using the
> ESRI
> shape file data. The application is able to do panning, zooming,
> querying,
> layer control, etc. operations. Now as a part of second phase of the
> project, I want to access the Oracle Spatial data from MapServer and
> publish on browser. We made a trial but failed to achieve the objective.
> In
> this regard, I coding the following map file
> LAYER
> NAME "Bound"
> STATUS ON
> DATA "GEOM FROM BOUND USING SRID 90112"
> TYPE LINE
> CONNECTIONTYPE ORACLESPATIAL
> CONNECTION "admin/admin at GisMaejo"
> METADATA
> "DESCRIPTION" "bounds"
> END
> #PROJECTION
> # "init=epsg:23947"
> #END
> CLASS
> NAME "bounds"
> COLOR 255 153 153
> TEMPLATE "ttt_query.html"
> END
> END
> I get an error: msDrawMap?()
> Can you help me about:
> 1. How to get PHP_Mapscript.dll with oracle support?
> 2. Could you elaborate the procedure for
> setting up the configuration for oracle oci.
> thank for advance
> _________________________________________________________________
> Add photos to your messages with MSN 8. Get 2 months FREE*.
> http://join.msn.com/?page=features/featuredemail
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
