[Mapserver-dev] PHP/mapscript and PNG problem
woodbri at swoodbridge.com woodbri at swoodbridge.com
Wed Jul 23 13:23:19 EDT 2003
David,
I was coming to the same conclusion until I backed out the PNG stuff
from PHP. I tend to build a lot of stuff into PHP incase I want to
use it but it is less stuff than RedHat builds in in their releases
:) I have built lots of other stuff without having other problems so
I am inclined to believe this is a PHP/Mapscript/configure bug for
Mapserver and have written a bug in bugzilla for this against 4.0 and
I hope it will be addressed. Part of the problem seems to be that the
libpng stuff is a little weird in the build area and their API
management - but then maybe I don't know what I'm talking about :)
Try building mapserver and php again and see if you can make your
problem go away. Oh report back here also.
-Steve W.
On 23 Jul 2003 at 11:09, David Graham wrote:
> Steve,
> This is very interesting. I had a very similar problem when I built
> the 4/21/03 3.7 nightly build on Win32 with PHP 4.3.1. In the end I
> never resolved the problem. In fact I have not built a single copy of
> Mapserver since. I came to the conclusion that my build environment
> was too currupted from building dozens of different opensource
> projects in dozens of versions. I have since requested a new clean
> machines to do my builds on. It has not shown up yet.
> Dave
> woodbri at swoodbridge.com wrote:
> >I am moving this to the dev list because I think I have run into a
> >serious problem that someone needs to evaluate as part of 4.0.
> >Here is what I think the problem is:  There seems to be two versions
> >of the libpng api although it is not totally clear to me, but if you
> >built PHP-4.3.1 with-pdf and with-png then mapserver CGI works fine
> >generating PNG images but PHP/mapscript dies in $img->saveImage();
> >call.
> >If I built PHP-4.3.1 without-pdf and without-png it works fine.
> >So what this looks like to me is that there is a conflict in the
> >libpng api calls where PHP loads uses a version that is not
> >compatible with what is expected by mapserver. Like the same entry
> >point name but different argument usage - or some similar situation.
> >I was using MS-3.7-may02-nightly, I tried MS-4.0-beta2, but ran into
> >other random crashes that I was not able to debug
> >Also, I built PHP-4.3.2 but it would not even run as a CGI, not sure
> >what is up with that. It looks like PHP is trying to parse the php
> >executable as the php script.
> >It does not escape me that I might (likely?) have some build
> >environment issue, but since the system is RH8.0 with most stuff
> >managed via RPMs, I not sure what would be foobar. I will look at
> >this more today.
> >I would be open to other thoughts or ideas.
> >I will forward my configure scripts when I get back to the office.
> >-Steve
> >On 17 Jul 2003 at 15:46, woodbri at swoodbridge.com wrote:
> >>OK, my turn to ask a question :)
> >>Run RH8.0, MS-4.0-b2, GD-2.0.15, gdal-1.1.9, php-4.3.2, using RH
> >>libpng-1.2.2-8
> >>I can generate a PNG image using mapserv but I crash in
> >>PHP/Mapscript $img->saveImage(...) call both use the same mapfile.
> >>I had the same problem using MS-3.7-may03-nightly, using GD-2.0.15,
> >>gdal-1.1.8, php-4.3.1 which pretty much points at the libpng.
> >>Oh yeah! Both GIF and JPEG work in both of the configuration.
> >>So has anyone else run into this?
> >>What are other people running on RH8 for libpng?
> >>Any other ideas?
> >>-Steve
> >>_______________________________________________
> >>Mapserver-users mailing list
> >>Mapserver-users at lists.gis.umn.edu
> >>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> >Mapserver-dev mailing list
> >Mapserver-dev at lists.gis.umn.edu
> >http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
> David W. Graham
> Director of Geospatial Applications Development
> information integration and imaging, LLC
> 201 Linden St, Third Floor
> Fort Collins, CO 80524
> (970) 482-4400
> dgraham at i3.com
> http://www.i3.com
