[Mapserver-dev] PHP/mapscript and PNG problem
David Graham dgraham at i3.com
Wed Jul 23 13:09:16 EDT 2003
Steve,
This is very interesting. I had a very similar problem when I built the
4/21/03 3.7 nightly build on Win32 with PHP 4.3.1. In the end I never
resolved the problem. In fact I have not built a single copy of
Mapserver since. I came to the conclusion that my build environment was
too currupted from building dozens of different opensource projects in
dozens of versions. I have since requested a new clean machines to do my
builds on. It has not shown up yet.
Dave
woodbri at swoodbridge.com wrote:
>I am moving this to the dev list because I think I have run into a
>serious problem that someone needs to evaluate as part of 4.0.
>Here is what I think the problem is:  There seems to be two versions
>of the libpng api although it is not totally clear to me, but if you
>built PHP-4.3.1 with-pdf and with-png then mapserver CGI works fine
>generating PNG images but PHP/mapscript dies in $img->saveImage();
>call.
>If I built PHP-4.3.1 without-pdf and without-png it works fine.
>So what this looks like to me is that there is a conflict in the
>libpng api calls where PHP loads uses a version that is not
>compatible with what is expected by mapserver. Like the same entry
>point name but different argument usage - or some similar situation.
>I was using MS-3.7-may02-nightly, I tried MS-4.0-beta2, but ran into
>other random crashes that I was not able to debug
>Also, I built PHP-4.3.2 but it would not even run as a CGI, not sure
>what is up with that. It looks like PHP is trying to parse the php
>executable as the php script.
>It does not escape me that I might (likely?) have some build
>environment issue, but since the system is RH8.0 with most stuff
>managed via RPMs, I not sure what would be foobar. I will look at
>this more today.
>I would be open to other thoughts or ideas.
>I will forward my configure scripts when I get back to the office.
>-Steve
>On 17 Jul 2003 at 15:46, woodbri at swoodbridge.com wrote:
>>OK, my turn to ask a question :)
>>Run RH8.0, MS-4.0-b2, GD-2.0.15, gdal-1.1.9, php-4.3.2, using RH
>>libpng-1.2.2-8
>>I can generate a PNG image using mapserv but I crash in PHP/Mapscript
>>$img->saveImage(...) call both use the same mapfile.
>>I had the same problem using MS-3.7-may03-nightly, using GD-2.0.15,
>>gdal-1.1.8, php-4.3.1 which pretty much points at the libpng.
>>Oh yeah! Both GIF and JPEG work in both of the configuration.
>>So has anyone else run into this?
>>What are other people running on RH8 for libpng?
>>Any other ideas?
>>-Steve
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>Mapserver-dev mailing list
>Mapserver-dev at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
David W. Graham
Director of Geospatial Applications Development
information integration and imaging, LLC
201 Linden St, Third Floor
Fort Collins, CO 80524
(970) 482-4400
dgraham at i3.com
http://www.i3.com
