[Mapserver-dev] LABEL Test, Errors Not Returned
    Steve Lime
    steve.lime at dnr.state.mn.us
    Mon Jun  2 21:06:59 EDT 2003
Frank: Ok, this map file should have thrown an error before and should
now as well. Basically you're drawing a point with no color. That's not
allowed. If there were a color then a style would've been initialized
and all would be well. We need code to check for absence of styles. I
don't think that's as simple as it sounds because of the way MapScript
figures in. I'll file as a bug. In the meantime just add "COLOR 0 0 0"
to your test case CLASS object and it should run.
Steve
>>> Frank Warmerdam <warmerdam at pobox.com> 05/30/03 2:39 PM >>>
Steve, or anyone,
One map in my autotest suite (msautotest/misc/label_pc256.map) uses the
following definition but when I run it now I get no output (and no
error).
   LAYER
     NAME fonttest
     TYPE POINT
     STATUS DEFAULT
     FEATURE
       POINTS 450000 6500000 END
       TEXT "BIG_AND_small test"
     END
     CLASS
       LABEL
         COLOR 0 0 0
#       BACKGROUNDCOLOR 200 200 100
         FONT lucida
         TYPE truetype
         SIZE 20
       END
     END # CLASS
   END
Tracking down inside the code it seems the style structure is
uninitialized in msGetMarkerSize() at this test:
   if(style->symbol > symbolset->numsymbols || style->symbol < 0)
return(MS_FAILURE);
(gdb) p *style
$7 = {color = {pen = 1108521444, red = 1108521444, green = 16, blue =
17},
   backgroundcolor = {pen = 135193248, red = 135193296, green = 0, blue
= 17},
   outlinecolor = {pen = 4610119, red = 1108521444, green = 16, blue =
81},
   symbol = 1598311748, symbolname = 0x41455243 "", size = 1313818964,
   sizescaled = 1096040772, minsize = 1162893652, maxsize = 2034384211,
   offsetx = 1428186484, offsety = 829713993, antialias = 1850286134}
This is a clean build from CVS with gd-2.0.12.  Have requirements on the
LAYER syntax changed in the last month or two since I last ran the test
suite?
Also, I see that SUPPORTS=TTF no longer exists.  Is SUPPORTS=FREETYPE
equivelent?  I check these tags in my autotest to decide which tests
should
be run.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
