[Mapserver-dev] Draw line with antialias
andrea.rogges at virgilio.it andrea.rogges at virgilio.it
Tue Jun 17 09:02:28 EDT 2003
Dear Steve,
thanks for your support, you are right when you say that drawing a single
line (deep a single pixel) with the antialias, more or less, we are able
to draw with different styles; the problem is get to draw a single line
with the antialias: which kind of style do I have to use? Do I have to specify
it or is enough to specify the LAYER as LINES?
Andrea.
>-- Messaggio originale --
>Date: Fri, 13 Jun 2003 12:51:41 -0500
>From: "Steve Lime" <steve.lime at dnr.state.mn.us>
>To: <assefa at dmsolutions.ca>,<andrea.rogges at virgilio.it>
>Cc: <mapserver-dev at lists.gis.umn.edu>
>Subject: Re: [Mapserver-dev] Draw line with antialias
>Based on the GD docs you may only draw single width lines antialiased.
>So if you want
>fat lines you have 1 option at the moment:
>  - draw a fat center with single pixel lines on the outside (styles
>with offsets)
>Ideally the CARTOLINE symbol type will be the way to go because is
>creates a thick line
>by creating a filled polygon and not a brush. So, in that case we could
>add to that code
>to draw an outline around the line polygon that could be antialiased. I
>don't believe the
>author of that code has mucked with GD antialiasing yet. I will mention
>it to him though.
>Steve
>>>> <andrea.rogges at virgilio.it> 06/13/03 11:15AM >>>
>OK, what is your suggest for obtain a line drawing with antialias?
>>Date: Fri, 13 Jun 2003 11:10:18 -0500
>>Since you're using an ellipse (a brush) the output cannot be
>antialiased
>>with GD as it sits now.
>>Steve
>>>>> <andrea.rogges at virgilio.it> 06/13/03 10:55AM >>>
>>Here is my mapfile definition...
>>>Date: Fri, 13 Jun 2003 10:50:42 -0500
>>>Send your mapfile definition. You can tell if it's working by the
>>time
>>>it takes to generate a
>>>map. Antialiasing is SLOOOOWWWW.
>>>There are also some caveats to the GD support- these are GD issues,
>>not
>>>MapServer issues.
>>>For example, styled symbols (i.e. dashes) cannot be antialiased, nor
>>>can brushed lines. Overall
>>>I was pretty disappointed with the support as it sits now. I'm sure
>>it
>>>will bet better over time.
>>>Steve
>>>>>> <andrea.rogges at virgilio.it> 06/13/03 10:17AM >>>
>>>It doesn't work :-(...I use a shapefile layer only with lines...the
>>>problem
>>>can be in SYMBOL definition?
>>>>Date: Fri, 13 Jun 2003 11:10:01 -0400
>>>>From: Yewondwossen Assefa <assefa at dmsolutions.ca>
>>>>To: andrea.rogges at virgilio.it
>>>>CC: mapserver-dev <mapserver-dev at lists.gis.umn.edu>
>>>> From what I can see it the code you have to specify antilaias TRUE
>>>in
>>>>the Style object :
>>>> CALSS
>>>>     Style
>>>>        ANTIALIAS TRUE
>>>>      END
>>>>andrea.rogges at virgilio.it wrote:
>>>>>Sorry for my previous message, taking order of dll's now it works
>>>>>But the question now is: how can I draw line with antialias ?
>>>>>>Date: Fri, 13 Jun 2003 09:27:05 -0400
>>>>>>CC: mapserver-dev at lists.gis.umn.edu
>>>>>>New binaries are at :
>>>>>>http://www2.dmsolutions.ca/mapserver/dl/mapserver-4.0-dev-win32-php4.3.2.zip
>>>>>>>Thanks very much ;-)
>>>>>>>Andrea.
>>>>>>>PS: where can I find new files ?
>>>>>>>>Date: Thu, 12 Jun 2003 11:45:37 -0400
>>>>>>>>To: Daniel Morissette <morissette at dmsolutions.ca>
>>>>>>>>CC: andrea.rogges at virgilio.it, mapserver-dev at lists.gis.umn.edu
>>>>>>>>I will add that to the makefiles and It will be available in
>the
>>>next
>>>>>>>>binaries sometime this afternoon.
>>>>>>>>Later,
>>>>>>>>>>The results is this message:
>>>>>>>>>>"loadStyle(): GD library error: Antialiasing support is not
>>>available.
>>>>>>>>>>Get a newer version of GD!"
>>>>>>>>>>What can I do? Do I need to recompile MapServer with GD
>>v2.0.15
>>>instead
>>>>>>>>>>of v2.0.12?
>>>>>>>>>I fixed this after the 4.0 beta for the Unix version.  For the
>>>Windows
>>>>>>>>>version, a -DUSE_GD_ANTIALIAS compile flag will have to be
>>added
>>>to
>>>>>the
>>>>>>>>>makefiles.
>>>>>>>>Assefa Yewondwossen
>>>>>>>>Software Analyst
>>>>>>>>Email: assefa at dmsolutions.ca
>>>>>>>>http://www.dmsolutions.ca/
>>>>>>>>Phone: (613) 565-5056 (ext 14)
>>>>>>>>Fax:   (613) 565-0925
>>>>>>>_______________________________________________
>>>>>>>Mapserver-dev mailing list
>>>>>>>Mapserver-dev at lists.gis.umn.edu
>>>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>>>>>>Assefa Yewondwossen
>>>>>>Software Analyst
>>>>>>Fax:   (613) 565-0925
>>>>Assefa Yewondwossen
>>>>Software Analyst
>>>>Fax:   (613) 565-0925
