[Mapserver-dev] Re: Layer processing...
Tue Jun 17 12:49:05 EDT 2003
Steve Lime wrote:
> Frank: I added to code last night to allow changing of bands via URL,
> and added a block to write out any processing stuff when the mapfile is
> saved. It's all in mapfile.c in loadLayerString and writeLayer. Could
> you just give it a quick once over to make sure I didn't miss anything?
> Thanks!
Steve,
I looked it over and it seems fine.
Why can only the BANDS processing item be changed?  In an effort to avoid
security holes?  I think that always letting clients select other band
combinations should not even be enabled by default.  I don't know too
much about the mechanism used to restrict what options can be set in the
URL though I have seen some discussion of it.  Can it be extended to items
for the PROCESSING flag?
I have cc:ed this to the dev list since my last email directly to you was
bounced by UMN as being from an illegitimate from address ... I guess pobox.com
has made it into some SPAM list or other.
Best regards,
