[Mapserver-dev] Issue with undefining string attributes
using mapscript
Steve Lime
steve.lime at dnr.state.mn.us
Tue Mar 11 15:09:12 EST 2003
See below for my exchange with the Swig folks...
Steve
Steve Lime writes:
> Thanks Dave!
> >>> David Beazley <beazley at cs.uchicago.edu> 12/09/02 10:44 AM >>>
> Steve Lime writes:
> > Um, yup it is. Simply switching:
> > if (arg1->name) free((char*)arg1->name);
> > arg1->name = (char *) malloc(strlen(arg2)+1);
> > strcpy((char*)arg1->name,arg2);
> > to:
> > if(arg2) {
> > } else
> > arg1->name = NULL;
> > Seems to fix things. Now, how to get these changes made?
> This is probably being controlled by a typemap in Lib/swig.swg.
> I'll take a look.
You can try sticking this in your interface (or making mods in
swig.swg).
Cheers,
Dave
/* Default typemap for handling char * members */
#ifdef __cplusplus
%typemap(memberin) char * {
if ($1) delete [] $1;
if ($input) {
$1 = ($1_type) (new char[strlen($input)+1]);
strcpy((char *) $1,$input);
} else {
$1 = 0;
%typemap(memberin,warning="451:Setting const char * member may leak
memory.") const char * {
if ($input) {
} else {
$1 = 0;
%typemap(globalin) char * {
if ($input) {
} else {
$1 = 0;
%typemap(globalin,warning="451:Setting const char * variable may leak
if ($input) {
} else {
$1 = 0;
#else
if ($1) free((char*)$1);
if ($input) {
$1 = ($1_type) malloc(strlen($input)+1);
strcpy((char*)$1,$input);
} else {
$1 = 0;
if ($input) {
} else {
$1 = 0;
if ($input) {
} else {
$1 = 0;
if ($input) {
} else {
$1 = 0;
