SV: [Mapserver-dev] routing
BVT at sns.dk BVT at sns.dk
Thu Mar 13 05:31:48 EST 2003
Try the following search on google: routing +"c" +Dijkstra
It will give you lots of hits regarding one (Dijkstra) of several routing
algorithms. If you follow some of the links you'll probably find c sources
for several other routing algorithms.
At least one of the hits
"http://computer.howstuffworks.com/routing-algorithm4.htm" contains a c
implementation of Dijkstra's shortest path algorithm.
regards
Bo Thomsen
GeoConsult I/S
Denmark
-----Oprindelig meddelelse-----
Fra: karthik achu [mailto:karthikachu at postmark.net]
Sendt: 13. marts 2003 11:00
Til: mapserever-users at lists.gis.umn.edu
Cc: mapserver-dev at lists.gis.umn.edu
Emne: [Mapserver-dev] routing
Hi Listers,
I'm in search of a routing algorithm that can be incorporated with
mapserver.
Can anybody help me to find out one.
Is their any downloadable solutions.
Regards
Karthik
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
