[Mapserver-dev] msProjectRect for degenerate rectangles?
Ed McNierney
ed at topozone.com
Fri Mar 21 11:32:48 EST 2003
Steve -
Yes, I agree - that's what I've attempted to implement. I'm just also trying to cover the bases in the case of an *extremely* small rectangle, where, for example, minx is not exactly equal to maxx, but dx (which is (maxx - minx) / 100) *might* compare equal to 0.
- Ed
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Friday, March 21, 2003 11:22 AM
To: mapserver-dev at lists.gis.umn.edu; Ed McNierney
Subject: RE: [Mapserver-dev] msProjectRect for degenerate rectangles?
This really needs Frank's input since he's the resident projection
guru... My thought would be that in the case of a degenerate rectangle
the output should also be a degenerate rectangle and the projection
boils down to projecting a point.
Steve
>>> "Ed McNierney" <ed at topozone.com> 03/21/03 09:39AM >>>
Actually, the fix is slightly different than that. It's probably a bit
of overkill, but if dx == 0 and dy == 0 (i.e. both blocks of code are
skipped) then I passed both the minx, miny and maxx, maxy points to
msProjectGrowRect. They should be exactly the same point, but I always
worry about comparing floating-point numbers to 0. msProjectGrowRect
will take care of setting both corners of the rectangle.
// If both deltas are zero, the rectangle is small but we need to
do something
if ((dx == 0) && (dy == 0))
prj_point.x = rect->minx;
prj_point.y = rect->miny;
msProjectGrowRect (in, out, &prj_rect, &rect_initialized,
&prj_point, &failure);
prj_point.x = rect->maxx;
prj_point.y = rect->maxy;
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
Sent: Thursday, March 20, 2003 2:20 PM
Subject: [Mapserver-dev] msProjectRect for degenerate rectangles?
Folks -
Now that I can actually run queries on 3.7, they don't work <g>. It
appears that doing a simple single-layer point query (i.e. what object
is this point in) for a data layer that's not in the MAP file's native
projection doesn't work. The query point is used to initialize a
rectangle with no TOLERANCE values, so msQueryByPoint creates a
degenerate rectangle object (minx == maxx, miny == maxy) and passes it
to msProjectRect. It *appears* that msProjectRect does the wrong thing
- it looks to see if dx (deltax) is greater than 0, and calls
msProjectGrowRect, then looks to see if dy (deltay) is greater than 0
and calls msProjectGrowRect again.
If dx == 0 and dy == 0 then the output rectangle's values are copied
from prj_rect, which was never initialized. So I get goofy results and
the query doesn't work.
I'm really asking about what msProjectRect should do when passed a
degenerate rectangle. It seems to me that there's nothing really wrong
with such a rectangle, and it ought to handle it just fine (i.e. the fix
should be in msProjectRect). But I don't know enough about its usage to
be sure.
It seems like modifying the two tests (if (dx > 0), if (dy > 0)) to
simply be >= tests would be fine. Thoughts would be appreciated -
thanks.
- Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
