[Mapserver-dev] OGR debugg
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 26 11:33:16 EST 2003
Daniel,
Do you mind if I modify the msDebug() calls in mapogr.cpp to only emit
routine debugging if layer->debug is set? This should be the correct
semantics for mapserver debugging right? Non-error debug info should only
be emitted if the layer or map debug flags are set? Debug info reporting
varous kinds of error conditions can be emitted even if the debug flags
aren't set, right?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
