[Mapserver-dev] OGR debugg
Daniel Morissette
morissette at dmsolutions.ca
Wed Mar 26 11:45:34 EST 2003
Frank Warmerdam wrote:
> Do you mind if I modify the msDebug() calls in mapogr.cpp to only emit
> routine debugging if layer->debug is set?
I don't mind at all, please do. I guess I should have done that
before. I'll do the same for the WMS/WFS layers now.
> This should be the correct
> semantics for mapserver debugging right? Non-error debug info should only
> be emitted if the layer or map debug flags are set? Debug info reporting
> varous kinds of error conditions can be emitted even if the debug flags
> aren't set, right?
I don't know if there was ever a clear agreement on this, but what you
suggest would make sense to me.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
