[Mapserver-dev] LABEL Test, Errors Not Returned
Frank Warmerdam
warmerdam at pobox.com
Fri May 30 15:39:09 EDT 2003
Steve, or anyone,
One map in my autotest suite (msautotest/misc/label_pc256.map) uses the
following definition but when I run it now I get no output (and no error).
LAYER
NAME fonttest
TYPE POINT
STATUS DEFAULT
FEATURE
POINTS 450000 6500000 END
TEXT "BIG_AND_small test"
END
CLASS
LABEL
COLOR 0 0 0
# BACKGROUNDCOLOR 200 200 100
FONT lucida
TYPE truetype
SIZE 20
END
END # CLASS
END
Tracking down inside the code it seems the style structure is
uninitialized in msGetMarkerSize() at this test:
if(style->symbol > symbolset->numsymbols || style->symbol < 0) return(MS_FAILURE);
(gdb) p *style
$7 = {color = {pen = 1108521444, red = 1108521444, green = 16, blue = 17},
backgroundcolor = {pen = 135193248, red = 135193296, green = 0, blue = 17},
outlinecolor = {pen = 4610119, red = 1108521444, green = 16, blue = 81},
symbol = 1598311748, symbolname = 0x41455243 "", size = 1313818964,
sizescaled = 1096040772, minsize = 1162893652, maxsize = 2034384211,
offsetx = 1428186484, offsety = 829713993, antialias = 1850286134}
This is a clean build from CVS with gd-2.0.12. Have requirements on the
LAYER syntax changed in the last month or two since I last ran the test
suite?
Also, I see that SUPPORTS=TTF no longer exists. Is SUPPORTS=FREETYPE
equivelent? I check these tags in my autotest to decide which tests should
be run.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
