[Mapserver-dev] ALPHACOLOR?
Steve Lime
steve.lime at dnr.state.mn.us
Wed Nov 5 11:43:29 EST 2003
I believe Frank put that in place at the begining of the color
conversion. Not sure
what his intensions were, but I've not modified any of the GD related
code to use
it. No reason to document it at this point.
Steve
>>> Daniel Morissette <morissette at dmsolutions.ca> 11/4/2003 10:37:31 AM
Steve, and all,
We found a new keyword called ALPHACOLOR in the 4.0/4.1 source and also
a new ALPHACOLOR_ENABLED compile flag, but there seems to be no mention
of this anywhere in the docs. This compile flag doesn't seem to be
enabled by default either.
Is this ready to use or is it just the beginning of some work to
support
ALPHA in color values? Should something be added to the docs and the
configure script for this?
Thanks
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
