[Mapserver-dev] Speed Improvement Fix.
Alan Steremberg
alans at wunderground.com
Wed Nov 5 22:31:20 EST 2003
I am not sure if this changes the drawing behaviour, but I was able to
speed up one of the layers I was drawing by a factor of 4-6.
Here is the issue:
When drawing Overlay symbols, mapdraw caches everything using
'insertFeatureList'. insertFeaturelist is a linked list with a tail
insertion. This is n*log(n). I switched the algorithm to a head insertion
which is time n. It is possible that the lines will now draw backwards
(not sure if this is a problem) if it is, we should change the linked list
structure to have a last pointer that we can keep updated.
here is my modification:
mapfile.c:
/* AJS -- link the list the other way?? */
/* BEFORE --> */
#if 0
node->next = NULL;
previous = NULL;
current = *list;
while(current != NULL) {
previous = current;
current = current->next;
i++;
if(previous == NULL) {
*list = node;
} else
previous->next = node;
#endif
/* AJS */
/* AFTER, two lines of code */
node->next=*list;
*list=node;
Thoughts?
Alan
Alan Steremberg
415-543-5021 x 103
http://www.wunderground.com
