[Mapserver-dev] Speed Improvement Fix.
Alan Steremberg
alans at wunderground.com
Wed Nov 5 23:39:48 EST 2003
Actually it was O(n^2) :-)
Alan Steremberg
415-543-5021 x 103
http://www.wunderground.com
On Wed, 5 Nov 2003, Alan Steremberg wrote:
> Hi,
> I am not sure if this changes the drawing behaviour, but I was able to
> speed up one of the layers I was drawing by a factor of 4-6.
> Here is the issue:
> When drawing Overlay symbols, mapdraw caches everything using
> 'insertFeatureList'. insertFeaturelist is a linked list with a tail
> insertion. This is n*log(n). I switched the algorithm to a head insertion
> which is time n. It is possible that the lines will now draw backwards
> (not sure if this is a problem) if it is, we should change the linked list
> structure to have a last pointer that we can keep updated.
> here is my modification:
> mapfile.c:
> /* AJS -- link the list the other way?? */
> /* BEFORE --> */
> #if 0
> node->next = NULL;
> previous = NULL;
> current = *list;
> while(current != NULL) {
> previous = current;
> current = current->next;
> i++;
> if(previous == NULL) {
> *list = node;
> } else
> previous->next = node;
> #endif
> /* AJS */
> /* AFTER, two lines of code */
> node->next=*list;
> *list=node;
> Thoughts?
> Alan
> Alan Steremberg
> 415-543-5021 x 103
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
