[Mapserver-dev] Wingdings bug
Ned Harding
nharding at extendthereach.com
Thu Nov 6 11:49:33 EST 2003
Thanks for looking into that Daniel... I guess it seams like a FreeType
issue, in that the behavior is different from the windows TrueType renderer,
but mainly a bug that isn't a bug. Not too big an issue now that I've
figured it out. It only became an issue for me because I'm embedding
MapServer into a desktop product on windows and I have to make do with what
fonts a client will have.
Ned.
-----Original Message-----
From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
Sent: Thursday, November 06, 2003 8:23 AM
To: Ned Harding
Cc: mapserver-dev at lists.gis.umn.edu
Subject: Re: [Mapserver-dev] Wingdings bug
Ned Harding wrote:
> I found a post that said that Wingdings and other TrueType fonts that
> are not Unicode don't work, but... A little research in the debugger
> diving down into the FreeType library found that the WingDings
> characters are mapped into the range of 0xf000 to 0xf0ff. If you simply
add 61440 to a
> character code, it works just fine, i.e. CHARACTER "" maps to
the
> star (0xAB). This works fine in a kludgy kind of way, but violates my
> sense of style.
> I'm not familiar enough with the mapServer code base and all the
> libraries to fix this bug. Any ideas what piece of code should be
> responsible for mapping these characters up into this range? I'm
> guessing that the bug is in the GD library, but again, I'm not really
> sure.
It's not really a bug, it's just that wingding isn't a text font, it's a
symbol font, and for this reason the character codes had to be mapped to
a non-reserved area of the character map.
I found the following post which explains that:
http://www.freetype.org/pipermail/freetype/2001-July/004164.html
MapServer is just taking whatever input we provide and passing it to
freetype, so I'm not sure we can/should do anything about this unless we
want to add handling of character encodings everywhere in MapServer.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
