[Mapserver-dev] Shape bounds
Sean Gillies
sgillies at frii.com
Thu Nov 13 12:25:45 EST 2003
On Thursday, November 13, 2003, at 09:01 AM, Steve Lime wrote:
> Hi Folks: Looking for opinions. In mapprimative.c lives a function
> msAddLine that is the primary code for building shapes other than
> reading directly from shapefiles. That code does not maintain a shape
> bounding box. So should the bounding box be maintained:
> 1) withing msAddLine
> 2) by the code making repetitive calls to msAddLine
> Ultimately I just want to make sure that an accurate bounding box is
> available. Option 1 centralizes the responsibility, but option 2 is
> better for performance. After all, why set a bounding box until the
> full
> shape is done. I'm leaning towards 2 and just fixing on part of the
> label cache code.
> steve
2
It's not so bad for a programmer to set the bounds on a shape once all
lines have been added.
Sean
