[Mapserver-dev] EPSG:NONE
Daniel Morissette
morissette at dmsolutions.ca
Mon Nov 24 17:13:26 EST 2003
Jan Hartmann wrote:
> Daniel Morissette wrote:
>> Perhaps MapServer should try to support SRS=NONE, but we need to think
>> about the way to support this in a mapfile and internally. For
>> instance the spec also states that
>> "Clients should not attempt to overlay information whose SRS=none
>> with other information."
>> This restriction is important otherwise the behavior is undefined if
>> you request a geographical layer using SRS=NONE or if you try to
>> overlay two layers that don't have a SRS.
> Daniel, what is the problem with overlaying two layers without an SRS? I
> am working with unreferenced historical maps with superimposed
> architectural drawings digitized from the maps. I would like to publish
> these as WMS maps in a few months, but for now everything needs to be
> geo-referenced. This gives some distortion as the maps are not exactly
> to scale. MapServer can overlay non-referenced images without problem,
> so why could its WMS version not do the same?
If you know that the two layers with SRS=NONE represent the same area
and can overlap then there is no problem (which seems to be the case
with your historical maps). But just putting SRS=NONE in a capabilities
document doesn't tell the client that it is safe to combine two layers.
OTOH when two layers have SRS=EPSG:4326 then it is clear that it's OK
to draw them on top of each other.
We could let MapServer overlay images with SRS=NONE and let the users
deal with the unpredictable results I guess.
BTW, should we allow zooming on layers with SRS=NONE? Does this assume
that the BBOX coordinates are in pixels in this case? I think this
behavior is clarified with the CRS:1 that replaces SRS=NONE in WMS 1.2,
I would have to re-read that part of the spec before we implement anything.
> As to overlaying two layers with different SRS's, I'm not sure if the
> results are "undefined". You can perfectly well combine coordinates from
> different base systems; it just doesn't make sense, as you get maps with
> wildly divergent parts. That is what people do who try to display a
> latlong map in a geographic projection and "don't see anything" as a
> result. It's not impossible, you just don't get what you expected. I
> guess that is why the spec says you should not attempt it: you can do it
> but it is not wise.
MapServer is smart enough that if you try to overlay *WMS* layers with
different SRS then it will reproject them to use the same map projection
and the result is fully valid. That's different from having two layers
with SRS=NONE since NONE has no absolute reference to anything.
> As I said, I would like very much this SRS=NONE capability. I refrained
> from asking for it, since I thought it was outside the WMS specs, but
> now I know it is in 1.1.1 (thanks Tom), I would like to add my 0.02
> request for it.
If we implement this as stated in the spec then your problem won't be
solved since we won't allow overlaying layers with SRS=NONE. I agree
personally with this restriction of the spec, but I understand why you
need this and I guess it would make sense to leave the implementation
flexible enough to let MapServer overlay layers with SRS=NONE and let
the user deal with whatever result they get.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
