[Mapserver-dev] polygon outlines with classified layers
Jan Hartmann
jhart at frw.uva.nl
Thu Nov 27 07:58:24 EST 2003
Bart van den Eijnden wrote:
>> Also is it possible, to only draw an outline when there is a
>> border/transition between two classes? If I put on outline in all of
>> my classes I have the problem that adjacent polygons which belong to
>> the same class are drawn with an outline in between. In an ideal
>> situation I would want only to have outline when there is a transition
>> of classes.
Daniel Morissette wrote:
> Um... I can't think of a way to do that right now. You would almost need
> to pre-merge your polygons.
> Well... maybe there is something you could do, but that's really a hack
> and may not work very well, you would need two layers:
> 1- First draw all your polygons as a line layer with a thickness of 2-3
> pixels.
> 2- Then use a second layer to draw all your polygons again but with no
> outline this time. This will have the effect of erasing the common
> borders and will erase only the 50% of the width of the outer borders.
> Daniel
Alternatively, use PostGIS 0.8 with the new topological operators (UNION
I think). You can write quite easily a DATA statement with a query
combining al the polygons you want, and color and outline the resulting
combined polygons. This is more elegant than Daniel's solution, but I am
not sure if it is fast enough for heavy server load. IMO very much worth
an experiment.
Jan
