[Mapserver-dev] upcoming 4.0.1 release
Yewondwossen Assefa
assefa at dmsolutions.ca
Tue Oct 7 11:31:57 EDT 2003
I have added the support for the ogc FilterEncoding. Most of the
things are commited. I am just running through the OGC tests. I will
commit all the stuff before Friday and update also the log for this.
Later,
Sean Gillies wrote:
> Hi all,
> I checked with Steve and Daniel about making a 4.0.1 release and we would
> like to release thursday. Here are the additions to the history file:
> Version 4.0.1 (2003-10-09)
> - Fixed problem with cloned mapObj's fontset->filename pointing to the
> original mapObj's fontset->filename
> - Fixed error in MapScript zoomRectangle method (bug 449)
> - Corrected use of error stack in Python MapScript exception handler
> - Fixed memory leaks in MapScript when using mapObj's clone,
> and in methods that return an imageObj
> - Fixed double free in SWIG imageObj's free method (bug 393)
> - Fixed seg fault with WMS GetFeatureInfo of type text/html
> From looking in the logs, there doesn't appear to be any other work
> going on. Does anyone have any uncommitted work in the 4.0 branch? If so,
> could you hold off on committing until Steve or Daniel can tag the files?
> Only 51 more bugs to squish in 4.0. Actually, 5 of these are version
> 4.0 enhancement requests that could be changed to 4.1, reducing the
> 4.0 bugs to 46. Are there any objections to me editing all 4.0 or
> unspecified version enhancements to be version 4.1?
> thanks,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://www.frii.com/~sgillies
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
