[Mapserver-dev] Re: [Mapserver-users] Mapscript drawQuery() on big PostGIS layers
doesn't work properly ?
Paul Ramsey
pramsey at refractions.net
Wed Oct 15 12:25:58 EDT 2003
David Blasby wrote:
> Whats happening is that postgresql is using the spatial index (which
> presumably returns the entire layer), then does a sequencial scan to
> find the rows with the "filter" attributes.
Incidentally, it is worth pointing out that the currect behavior for
query functionality is almost painfully unsuited to database backends.
The shapefile heritage really shows through in the query workflow, which
if I am not mistaken is "tell me the record numbers of all records of
interest (that match the criteria)", "give me record 1", "give me record
2", etc. To emulate this, we do exactly as asked. Give the list of
record numbers (unique ids in our case) and then perform repeated
queries -- the opposite of efficient, given the capabilities of the
backend. Obviously it would be preferable to turn the query into a
single resultset and then scroll through it, once.
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
