[Mapserver-dev] MetadataURL
Tom.Kralidis at CCRS.NRCan.gc.ca
Wed Oct 15 09:25:37 EDT 2003
I am surely for this enhancement!! I also suggest DataURL to be added.
For Chameleon, this would just be another element parsed out of the Web Map
Context Document, which supports DataURL and MetadataURL
..Tom
Tom Kralidis
Systems Scientist
Canada Centre for Remote Sensing
Tel: +01-613-947-1828
http://www.cgdi.ca/
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Wednesday, October 15, 2003 9:15 AM
> To: bartvde at xs4all.nl
> Cc: mapserver-dev at lists.gis.umn.edu
> Subject: Re: [Mapserver-dev] MetadataURL
> bartvde at xs4all.nl wrote:
> > in the WMS specs (starting at 1.1.0 if I am not mistaken)
> there is an
> > option to link a layer to its metadata using the
> MetadataURL element.
> > I am very much in need of such a parameter for my
> Mapserver/Chameleon
> > application.
> > I suppose supporting this would require an additional WMS_
> variable for
> > the layer metadata object in the map file.
> We would need to add a support for a new wms_metadataurl
> metadata in the
> WMS GetCapabilities code. This is not really a change to the mapfile
> format since it's a metadata entry and the mapfile parser
> doesn't do any
> validation on metadata.
> Then to have access to this information in chameleon the WMS
> capabilities parser code in Chameleon would have to be enhanced to
> handle this new piece of information. There could be more or
> less work
> involved in Chameleon depending on what you want to do with this URL.
> > I do not have any insight in the consequences of changes in
> the Map file
> > format (php mapscript etc.?), and I suppose this would
> require everybody
> > to be in favour the change.
> > Does anybody have any thoughts on this, or are there plans
> to incorporate
> > this in the mapfile format?
> There's already a bug about adding this to the WMS capabilities in
> MapServer, you could add yourself in the CC of the bug to be informed
> when we get to it:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=438
> Daniel
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
