[Mapserver-dev] MetadataURL
Daniel Morissette
morissette at dmsolutions.ca
Wed Oct 15 09:14:41 EDT 2003
bartvde at xs4all.nl wrote:
> in the WMS specs (starting at 1.1.0 if I am not mistaken) there is an
> option to link a layer to its metadata using the MetadataURL element.
> I am very much in need of such a parameter for my Mapserver/Chameleon
> application.
> I suppose supporting this would require an additional WMS_ variable for
> the layer metadata object in the map file.
We would need to add a support for a new wms_metadataurl metadata in the
WMS GetCapabilities code. This is not really a change to the mapfile
format since it's a metadata entry and the mapfile parser doesn't do any
validation on metadata.
Then to have access to this information in chameleon the WMS
capabilities parser code in Chameleon would have to be enhanced to
handle this new piece of information. There could be more or less work
involved in Chameleon depending on what you want to do with this URL.
> I do not have any insight in the consequences of changes in the Map file
> format (php mapscript etc.?), and I suppose this would require everybody
> to be in favour the change.
> Does anybody have any thoughts on this, or are there plans to incorporate
> this in the mapfile format?
There's already a bug about adding this to the WMS capabilities in
MapServer, you could add yourself in the CC of the bug to be informed
when we get to it:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=438
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
