[Mapserver-dev] OGC ServiceExceptions and invalid layers
Paul Spencer spencer at dmsolutions.ca
Wed Oct 22 13:58:12 EDT 2003
Filed bug 466 for this, and added most of the commentary so far.  Please
continue the discussion in the bug.
I did not add any additional cc:'s to this bug, so please feel free to visit
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=466
and add yourself if you are interested.
Tom K.  you mentioned a related bug, could you note that in this bug
please ... or set up a dependency.
Cheers,
Paul
PS: I've noted the bug against the WFS client since that was the reason
why this came up.
PPS: Steve L, I believe Assefa would be the one to tell you what we were
able to do with the filters.  There were several limitations that he was
not happy with, but we had made a conscious decision not to implement
anything that was not directly supported in MapServer.  It is highly
likely that missing stuff will be added over time, but it would require
small to large changes in mapserver and that was out of scope for this
contract.
Cheers,
Paul
Daniel Morissette wrote:
> Steve Lime wrote:
>> Are you going to add a generic msReturnOGCError function to maperror.c?
>> That way all the
>> OGC services can use it.
> Well, we could do that if there is really a use for such a function (I
> thought that returning the exception via the error stack would be
> enough).  The main part of the work is to detect exception in what is
> returned by remote servers and this would likely end up in mapows.c to
> be shared by all OGC web services.  From there we could add
> msReturnOGCError(), but what would this function do and where/when would
> it be used?
|Paul Spencer                           spencer at dmsolutions.ca    |
|Applications & Software Development                              |
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
